narrowed 60 four link ride height
twin 640
alberta
Im installing a narrowed diff and a four link rear clip but im paused on ride heigth as im using a magnum front k-member with 2 inch drop spindles.any info to this matter would be great .wondering how it sits with bb on front
You'll have to know the springs rate and lower accordingly or just add weight on the front, or set the ride height you want and then when you add springs adjust them after to where it was built.
I have all the springs but I need the correct height as I don’t want the front in the air or the reaction times slow
Two way adjustable with 3200 springs in back and front has qa1 coil overs but 1.5 inch drop spindles. If that helps
no two cars are the same, it takes time and practice to get the front to rear ride height correct for optimum launch and with a 4 link it may even be different from side to side due to launch torque/chassis "twist" what 4 link are you installing?
Same here , had to go to 250 springs on front , the front end came w/ 500# springs , I tried 300# springs first, had no front end rise at all, too stiff, 250's much better.
W/ my 205 70 15 front tires , I try to keep my center front fender height around 25 3/4ish inches. Had to run the adjusters up a fair amount to get that , but its stored energy I guess >
full caltrac system on the rear w/ 295 65 15 drag radials or 295 60 d15 tires back there.
Seven year thread back from the dead.
This one is a little different as it is the original poster responding. Some builds take time. LOL
