[WANTED] Heat Riser for 273 with Stromberg WW carb 2 barrel
I think we are confused by your needs. A heat riser is on the exhaust manifold and has nothing to do with the carb. What is it that you need?
Dashpot maybe, post up a picture of what your looking for. Never know someone might have it!
Are you looking for a complete manifold w/heat riser or just parts to repair a heat riser? Does your manifold still have the "butterfly" valve in it? Does it rotate freely?
