Bobzilla
Post 215 hose length is not an issue at all, at this power level. Your bottle pressure will remain fairly high during during your short blasts at low horsepower settings, so you will not feel a difference or see it on the plugs even with vastly different lengths, within reason. If one hose wraps around the engine while the other is short, you may see a little difference on the plug, but I still doubt it. You'll have enough pressure and supply to keep it liquid at the jet through the longer line.
