Hey there, just went through fitting a 73 Dart Sport rear seat into a 72 Duster and it worked out well, the body hooks seemed to be in the same spots. What you must be mindful of is the wheel base of your car and the donor.... which includes 2 door and 4 door cars.... A scamp or Dart swinger with the shorter wheelbase has a different dimensions in the rear... narrower for one. So in a nut shell, your Dart back seat better be from a Dart Sport or you may have to rig up a custom install if its the narrower seat. Best of luck. Cheers. Jimmy
