Does anyone know where I can find a set of steel rocker shaft hold down blocks for W2 heads?
Thank you.
Thank you.
Yes, steel.. I'm having my stroker 360 with W2 Econo heads inspected and my engine guy noted there was too much lateral rocker movement on some of the rockers and a couple of the aluminum hold downs got scored, so he's recommending steel hold downs.Steel? Not aluminum?
That's what I ordered. Thank you!
