Found a carb tag someone may need. Can't find ID anywhere. Hope someone can help. #4540S. Thanks
Makes sense. I replaced the carb on my 69 Charger RT/SE with a Holley. ThanksIs it 4640S? If so, it matches the 92 broadcast sheet code.
1969 440 HP with AC in B & C bodies.
I went back to double check and from the back it clearly is a 6 not a 5. 4640S. I really appreciate you taking the time to help us out!!!!Is it 4640S? If so, it matches the 92 broadcast sheet code.
Thanks4640 C-4-AVS 69 440 A-134 A/T & A/C
Shoulda been from an AVS.
