Run 20 psi warm tire. Drive thru the water box and do a quick burnout to clean the tire.I had about 20psi in the tires. I thought it was an good burnout to get the tires warm but definitely not a huge smoke show. The car launched straight and I think the track was cold since this pass was at 8pm and the outside temp was in the low 60s with a little wind. I pulled the plugs and they all look like this which I think is lean...
My bad! It looked completely white on my phone screen, looked at on monitor and it looks pretty good. But you are correct, you would have to see inside the shell to determine what it’s doing on top end. A little more color on it or wouldn’t be a bad thing, though.How can you see it's lean at speed? Looks like idle and cruise are fine, but you can't see WOT in a picture like that. He needs to cut the shell off.
I think you are at sea level. I'd guess your car's combo should be about mid 12's (with more cfm's). That's good news, always fun to find more.
As stated before, no video of the race but here is the burnout before my run.
67 Dart in my avatar, 340 IMM RHS X heads, 750 Proform, Airgap, XS274S, 1.6 Hughes rockers, TTI step, 999 low gear set lockup disabled with TA 3200 tight converter, 4.10/27" or 26" tire.Mderoy340, what car do you have and what does your car run?
