What should my 360 run
Your in Reno never mind still not bad for that high up
I might be pretty generous too... our 3.55 geared 410 in the dart ran 12.4's, but that was like 7000+ ft DA..you're just gonna have to take it out and let everyone know how it did.:thumbsup:
WHAt all was done to your engine combo then??[/Q
4.56 gears, M1 single plane, 250ish at .050 solid flat tappet.
I think I asked this years ago but I’ve forget. But I would love to know.
4.06” bore, 252/257 @.050 .550ish lift solid flat tappet, Edelbrock RPM heads with valve job, TTI headers, full 3” exhaust with H pipe, Holley red fuel pump with 3/8” line, 185 cranking PSI
With M1 single plane, Holley 830 with annular boosters, 4.56 gears, Hoosier quick time pro (27x10.50x15) ran 11.47
Switch to performer RPM intake, Holley 750 double pumper (4779), 3.91 gears, Mickey Thompson 255/60/15 drag radial ran 12.0
All steel body, full interior, 91 octane pump gas.
