I get it. But if the shaft had been relocated to optimize the geometry, it would have had more. Again, it's just a symptom. Clearance, or lack of, doesn't mean good geometry. Excessive sweep is also a symptom, and I'd bet a paycheck it still has that.
The rockers with a clearance issue are likely designed on a computer screen, with proper geometry (ie stand height) in mind. When mounted on the incorrect stand height, then it becomes a problem.
If stand height wasn't important, why has Trick Flow gone to the trouble of raising the rocker shafts considerably in both the big block and small block heads? And, why do they say to only use roller rockers with their heads? They could have just copied a factory head, just like everyone else. Btw, I should have the new T&D rockers for the TF small block heads next week.
