Iron Oxide
Are the heat control valve springs and hardware reproduced? My 170 has no springs on it. The valve isn't seized, but has been stuck in the "cold" position.
I've got it all apart to replace broken hardware and put in a set of Remflex gaskets and would like to restore the function of the heat control valve while I'm in there.
Thanks!
Thanks!
