[WANTED] Ignition connector
BWDart
New Braunfels TX
I replaced my ignition switch but the harness connector in the car fell apart. Anyone have a unusable harness they can cut the connector off of?
72 Dart
Thanks
Bruce
Can you post a picture of what you want to replace? I might have one on the column I just removed
Did the plastic disintegrate but the terminals are OK?
Generally better off using the existing terminals or crimping new ones on (rather than splicing).
Ya I was wanting to reuse existing terminals plastic is toast blue hot wire caused most of the problem
Here is a pic I need the dull white piece on top couldn't get to it to disconnect back is hurtin today
