[Found!] SBP Wheels & Tires in CA/NV/OR/UT etc...
hellfirechrome
Tahoe
Rating - 90.9%
10   1   0
EDIT: FOUND! Thanks everyone!
Got another A-body! WOOHOO! But... Those 13" wheels need to go, and the tires are rotten. So, Looking for 14" or 15" SBP wheels (and tires if ya got 'em!), 5 x 4" for stock Barracuda. Rallye, Cragar, Steelies, what have you got lying around? Thanks in advance!
Thanks in advance!
got these u.s. indy's 14x7's
14x4.5” wide, small bolt pattern with older tires on them. Were on my 66 wagon. Was asking $150 for the set.
I have a set of 14" turbine mags on my Dart that will be swapped out soon. The tires are junk but the wheels are in excellent shape. PM if interested.
Thank you guys, looks like the brake kit I'm buying needs 15" or larger (Only some 14" will fit, it's a crapshoot) and might as well go 4.5" BBP at this point! Thank you for responding!!
ssbc kits work with 14's here a duster i did , 10'' drum spindles with four piston calipers
You guys are the best! I actually just went and picked up a set of 16 inch American racing, I’m going to use the Wilwood front kit which needs a 15 inch wheel so I think it’s good to play it safe.
