Electric cooling fan sending unit options....
DGrace
Snow Hill, NC
Hello all - hope everyone is doing well. Looking for a sending unit to control the cooling fans on my big block Dart. I've read that it's best to go with a 2 wire unit if it's going to be mounted in aluminum ( aluminum heads, radiator & water pump housing). I've also seen external sensors (Derale I think) so I'm not sure which is best. Anyone have any "real world" advice as to which style or brand to go with? Thinking about running the Ron Francis dual relay setup because it's neat and somewhat compact. Any help to steer me into the right direction and avoid a headache or two would be appreciated. Thank you in advance. <><
I bought something from these guys couple years ago - a cooling fan to for my aftermarket AC coil. They sell just the thermostat controls if you need them. They were helpful and quick to answer my questions.
160'F TEMPERATURE ELECTRIC FAN THERMOSTAT WIRING RELAY SWITCH KIT 1/8" INCH NPT | eBay
