72DMag
Been thinking about the 451 that I am building. Most people upgrade to the .990 full floating piston pin but what about the 1.094 pressed pin? Is this a bad idea to run a pressed pin with a stroker? Is there a horsepower limit with that pin? All I can find is that people switch pins for weight reduction but I can't find anything that says its a bad pin for a stroker.
Lets say I build a 13:1 compression 451 would that pressed pin hold up with a hydraulic flat lifter cam shifting at 6000?
