BWDart
How do ya'll keep the bolts in place when connecting exhaust pipes? They are a real pita to do by youself. Thought about tacking bolts to manifold?
I like to use somewhat undersize bolts and lowest (IE grade 2) grade bolts I can get, so I can twist them off if I need to next time they come apart. This of course does not help holding them in place, but I've always managed to "rassle" them i
Sounds good I'll call the local dealerThe keepers I mentioned above are steel.
They were intact on my (then) 49 year old Valiant when I had to drop the Y-pipe to install a new oil pan gasket.
They held when I removed the nuts from below with my 1/2" drive impact.
So how 'kinda permanent' are you after? ;-)
I weld a tab on either the nut or bolt head.
How do ya'll keep the bolts in place when connecting exhaust pipes? They are a real pita to do by youself. Thought about tacking bolts to manifold?[/
Exhaust Lock Clips
