[Found!] SMALL BLOCK CYLINDER HEADS
I have 72 340 heads. They would need to be gone through and the larger valves could be added during the valve job and harden seats added. In CT
Indy cylinder heads Aero heads
ARO-CY-SB340 1968-1987 340-360 A-Engine 1.88X1.60 SS Valves, (2.02 Int. Valve add $100.00) 67-70cc Open Chamber Design, .509” Lift Springs, 160cc In. Port Volume........ 499.00
ARO-CY-SB915 Head-Same Features as Above 340-360 but Utilizes Select #915 or #587 Castings with a Larger Intake Port Volume .................... 699.00
Upgrade-2.02X1.60 11/32 Valve Stem Upgrade on 340-360 and 915-587 Assemblies Above, Lightens Valve Train Weight. ...................... 100.00
ARO-H3-144-3602 Head Bolts ARP OEM LA ................ 105.00
I have a pair of X heads, hard exhaust seats, New MP 2.08 1.60, aluminum bronze guides, not sleeved. Milled intake and block sides magnefluxed good. I'd have to see what I have in them if you would be interested.
have a set of J heads. 150 for the pair. they need to be gone threw. in IL
I have a set of 68 X heads 2.02 1.60s ported and gasket matched. I can send picture. These heads are ready to go.
I am interested. Please send pics.
