Correct PVC Grommet
512Stroker
We are all here because we are not all there.
Freedom, MO
I have a set of Mopar Performance die cast SBM valve covers. I was hoping to use a 1/2 inch outside diameter stock type Mopar PCV in the driver side cover, not the GM style PCV which is larger.
Does anyone have a source for the correct rubber PCV grommet that fits the thicker die cast cover and will accept a 1/2 PCV?
Thanks in advance
Try Mancinni Racing, that's where I got mine. My covers are in the garage attic and not going out there now, or I would get a picture .I have the PCV valve in the passenger side cover and a breather in the driver's side.
Nice
1/2 inch PCV right?
I believe so, it's been a year. Call them and ask. Will be going out to the garage later, I will go up into the attic and send a picture.
That's the grommet kit. Just sent 512 stroker pictures and numbers in a conversation.
As far as I know the original MP valve cover grommet was discontinued a few years ago. The kit was the only one I could find that has a groove wide enough to seat fully.
MP changed the part numbers on everything a few years ago and doubled the price, most stuff is still available, if you know the new part numbers.
