You can use the search feature. There's been quite a few (thousand) blurbs about this topic.I have a 1968 barracuda fastback I moved my leaf springs in onto my frame so I can put a bigger tire under it, What is the biggest tire and wheel that will fit without rubbing. "THANKS"
Thats for sure.... Google is your friend. I ordered 4 Cooper 215 70 R14s radials from Summit 2 days ago. $380 to my door, Cant complain about that. They are going to be here TODAY!!! Gads I wuv Summit!! Have all the **** to install my Chinese tire changer, drop ins, drill, bolts, & hammer bit.... Dyna beads confirmed that 2 ounces in each wheel will balance 'em out perfectly, & Rally's rims are all cleaned and painted up, so Imma go People!!You can use the search feature. There's been quite a few (thousand) blurbs about this topic.
I used those dyna beads when I worked for Harley. $7.50 for a 2 oz. bag. That and nitrogen, no spoke or adhesive weights to deal with. Clean man!!Thats for sure.... Google is your friend. I ordered 4 Cooper 215 70 R14s radials from Summit 2 days ago. $380 to my door, Cant complain about that. They are going to be here TODAY!!! Gads I wuv Summit!! Have all the **** to install my Chinese tire changer, drop ins, drill, bolts, & hammer bit.... Dyna beads confirmed that 2 ounces in each wheel will balance 'em out perfectly, & Rally's rims are all cleaned and painted up like a Slovenian Hooker, so Imma go People!!
Might be with disc brakes.I was lookin' at that RimsnTires link. According to their info a '72 A body has 5 on 4 1/2 bolt circle wheels
