[WANTED] 69 Barracuda - Rocker to Frame Front Splash Plate
Shakedownscott
Vermont
Hello,
Looking for these plates that are between the front frame rail and inner rocker panel. The ones on my barracuda project were cut and smashed in for fender well headers. Need both sides, hoping not to have to fix these :)
Anybody know what other A-bodies share this same part?
20190525_104659 by shakedownscott, on Flickr
splash sheild by shakedownscott, on Flickr
Thanks,
Scott
Scott 67-76 A bodies share the same platform with some differences over the years but that piece is the same on all the only difference is when it is a convertible, big block, or 4 speed car it has a reinforcement box added. I am parting out a Rusty Demon and am cutting those pieces off to sell $40 for the pair + shipping pics later.
Thanks for the information Dr.Sinister, glad that piece is common to all. Definitely would interested in checking out what you have for picture.
Could use the seam where this, the floor and firewall are welded together.
You can see the rust holes here.
I have to move a few things so I can get you a good look at them and also get a good look at the seam portion on the Driver side will tomorrow be ok I just got home from work.
Tomorrow is fine, thanks for looking.
I have quite a bit of body work still to go. I am just getting all the pieces together to repair all the cutouts from the fender well headers.
Scott parts have rust at floor attachments, below pics show condition I did not intentionally waste your time I thought they were in better shape. If you still want them $20 shipped if not no hard feelings.
I really appreciate you taking the time to look. There a little bit too far gone for me.
Thanks!
What is that part called? Does AMD reproduce it? I have the same problem on my dart.
I am not sure of the correct name but it ties the frame rail to the rockers on each side so I would call it a support brace.
JMO
I don’t know if anyone repops them.
Back when I restored my ‘cuda I had to make a set of these. My body man though that they were NOS and said that there was no way that I could make them. I just ran across the patterns that I made for them over 25 years ago but there are notes on them where I made adjustments but now i don’t remember what the notes mean.
