Stop in for a cup of coffee
Only one place downtown that has it just have to remember to throw a can in the car next time. Seems like whatever hoses Ryobi uses sucks with it. I like their gas tools usually super easy to start. Ordered two new carb kits for them both, cheap insurance. $20 each for new carb, plug, hoses, filters. Why not right?
I had the same problem with my Troy built stuff. A lot of the new stuff is using real thing, tiny diameter lines. The ones on my Troy built are thinner than vacuum hoses on my Polara
@halifaxhops
question on these hops, will the vines get cut off every fall ? Or do I leave them be?
In the fall just cut them back to the crown. You do know you need to let them grow on the average of 16' high right? Train them as fast as you can and limit the main vines to two per hill. Next spring you can gut new rhizomes from them and plant them also.
Ok thanks. I knew about the 16 ft thing but wasn’t sure about the rest. Thanks ray
Got the airbrush. haven't hooked it up yet.
Still had this.
Too bad there's nothing in it. :(
Looks like TCP global may be the only place that's selling some close. A few places have old stock but only gallons. Guessing either medium or slow will be best for an airbrush, esp this time of year.
Still had this.
What ya painting??
What ya painting??
First.
Touch up the firewall. The spray can of enamal the local store mixed isn't close enough.
really shows up under the shop lights.
I've got two cans of Lucite from 1989. One was the wrong color - Daffodil Yellow, but figure I can use that to practice.
The other is the what was sprayed in the engine compartment got sprayed that year. There's enough left to use in an airbrush. It should be a good match even though Joe touched up a little in the bay when he painted the exterior.
Well I never saw a dwell meter that looked like that. Is it a Kmart special? Kmart sucks
Its not a meter at all. And there's no electronics. Just a battery.
Just another way to set the points. But instead of measuring the gap, measure the actual dwell. Someone gave it to me years ago. I never used it.
Good Morning Everyone. Hope everyone had a great, safe Memorial Week End
Then this.
So it looks like this.
Taking my time on this one.
Never done anything like this. Was never into model or miniatures painting.
I saw a guy die like that. Shared the story here before. I didn't see it crush him but I drove by and saw him and said to my wife at the time how stupid it was and should stop and comment but I didn't. after about 5 miles saw an ambulance pulling out and saw it in the news the next day...STUPID!
