[SOLD] B,RB mopar honing plate
tonysrt
Northport, NY
Part # P4452194 honing plate for B family Engines. Price $200 plus shipping from 11768. I accept Paypal. Weighs approx. 25 lbs. Used once by a little old lady on Sunday.
Hi Tony, I liked the little old lady pitch. John here. Can you tell me the brand name and does the other side look as good as the top? Any instruction sheet or bolts. Thank you.
That's an actual Mopar Performance part. Now who actually made them for Mopar is probably unknown.
Tom
John it is a Mopar part # and was bought thru a Mopar dealer. It was used only once on a 440 block that I ran until I put a crate Hemi in my car. The other side has some marks were the plate was bolted to the block. No instructions or bolts came with it. when using it you should use correct head gasket you plan on using when assembling. Stock head bolts are all that is necessary unless using studs. here is pic of other side where bolts were attached.
thanks Tony, can you get a shipping cost to me? 63440, ewing, Mo. Or I could pic it up at a Trucking Depot cross the river at Quincy Ill. 63461. I'm not really up to date on this kind of shipping. Maybe it could come by Postal service? John. thank you
