No, sir. I don't think you have it right.
By milling both faces, yes, any intake will fit. That is a good thing. Putting heads on a different block isn't a problem either because.....any intake will fit. "jacked up" ??? WTF is that?
Are you feeling okay? Been drinking tonight ?
Doing it your way, the intake is now only a direct fit to the milled heads.
Doing it the right way, every intake fits not only the milled heads but ALL other heads.
Try some humility sometime. Being so sure of yourself sets you up to look foolish when you are proven wrong.
Sounds like some idiot already ruined (or made it to only fit one combination) one of the intakes, and your customer didn't know it. For a street engine, with used iron heads, I always mill the heads to get a flat surface.
No it is not complicated unless you make it. .120 off, standard tolerance? Not in a million years.
Graham is doing my intake. Here is pics with no end rail gaskets. I had to push it down pretty good to get the bolts in. The heads were milled .031 after these pics. Not sure what the spec is for milling the intake. He would not do the head intake face. He dissidents that’s the wrong way to do it. Kim
If my heads require milling I always have both surfaces milled and have never had any issues with intakes fitting.
Those heads will work on any other block.I never ever take any materiel from the intake side of the head unless it’s to get a port volume for some class thing or something.
The big ***** is if you do that, any intake will fit. So what? What about when you put the heads on a different block and now it’s jacked up.
Take it off the face of the intake manifold. Gaskets are cheap. Heads are not.
I'll add that if you use a thicker intake gasket...the cut intake could work on other blocks as well. Thing is if you measure and cut based off the thinner gasket... you will have more room for gasket compensating for the gap...cause it will be less now to start. I'd still rather cut the heads intake face once going beyond about .045No, sir. I don't think you have it right.
Do the math. I took .040 off the head. The width of the intake from high to low is at least .060 so that’s .100 right there.
I have no idea if some dick took .020 off the head before my customer for them. Who knows, maybe they already took .040 off for some reason.
Real life isn’t like the comic books.
Do what you want, but it will bite you in the *** someday doing it that way.
They're 'corrected' to fit an intake designed around all those other 'stock blocks'... I know you know this. You must just have your mind wrapped around something else.
All those whom agreed with YR need to do their math over again.
You are just widening what you narrowed by milling the heads ...and the intakes and as cast port windows leave plenty of room to massage and align.
You said one intake worked? Then the other did not? Never had a problem fitting intakes in real life. Not Ford, Not Chevrolet, Not MOPAR. But I can measure and know the numbers. Keep guessing away.
That's a very plausible situation....if you're YOU trying to dodge the ball.... lmao WHO IN THE HECK MILLS THE BLOCK DECK .080 TO GET A PISTON WHERE YOU WANT IT?! BUY THE RIGHT/CUSTOM PISTON...SAME MONEY AFTER .080 OFF EACH DECK AND THE CHINA WALL, CAUSE THATS HOW MUCH YOU'RE MILLING AT THAT RATE.They will work with any other block IF the deck heights are the same. Seriously? WTF?
I’ll give you an example and the numbers are rough because it’s been awhile since I milled my block, but it’s close.
To get the deck of my piston out of the deck .038, to get the CR I wanted I had to mill (again IIRC) .080 off the deck of the block.
So now, I screw up heads by milling the intake face of the head the amount needed to make an intake manifold fit it.
Now, I’m sick of those heads, so I put them for sale on FABO. And you buy them. And your block has only been milled...IDK...let’s say just .010 to clean it up. And you THINK any intake is going to drop right on? If you do, you are bat **** crazy.
That’s why you don’t mill the heads. Intakes manifolds and intake manifold gaskets are much cheaper than heads.
Come on, get real.
