Spark Plugs
It would be helpful if you told everyone about your engine and driveline
I just gave NGK 2635's a shot. So far car runs good. Replaced the set of Autolites that were perfect but replaced them anyways.
I used to have good results with Autolites, but the last few years, I have had an issue with the porcelin blowing out of the shell on a few. This seems to be a problem with the plugs that have "made in China" on the box. Customer service acknoledged(sp) the problem. Might be corrected by now. No problem with the plugs made in other countries.
I threw my boxes out, but I think my Autolites said made in Mexico. Who knows, they could have been made in China anyway.
I like NGK. The particular plug depends on year of cyl head, and whether the engine is stock or modified, and usage.
So far as I can tell, no numbers, it appears to be a late 60's to early 70's block, previous owner had a rebuilt put in.
Stock as can be so far as I can tell except for the 3:55 gears out back and the 2.5" exhaust...……..
It's a stock engine, late 60'7 early 70's. She's my cruiser and is driven locally and on highways on a weekly basis.
It's an automatic with 3:55's stuffed in a 7.25, it's soon getting it's 2 barrel setup......
I run the exact same type Champions in my '68 as the factory put in. I buy them as New Old Stock from eBay. No brand of plug has ever made it run better or worse at all.
