[SOLD] AC Compressor from '65 Barracuda 273
Bob Jasinski
Danville CA
I have a remanufactured Chrysler air conditioning compressor taken off a '65 Barracuda 273 with factory AC. It was given to me about 15 years ago from a friend that was doing a performance build and removed all the AC parts. The unit seems to be in good shape, still has residual oil in it and crankshaft turns freely with very good compression. I've done quite a bit of auto AC work over the years, and if I needed a compressor, I would use it myself. As you can see in the photos, it includes the brackets and clutch, and Its been in dry storage. This thing is heavy, 45 lbs without box, so figure 49 lbs boxed. Its not going to be fun to pack up for transport, so I need to get $100 for it plus freight cost. Bob in Danville, CA 94526
View attachment 1715543434 View attachment 1715543435 View attachment 1715543436 View attachment 1715543437
Would you happen to have the tensioner & bracket .Thanks
