Yeah I think that's a good plan, most converter companies are saying 4000- 4200 . the cam is a solid flat with 260-264 @.050 so it maybe small for my wanting to get the 9s but I'll only know when I try her out.
Alright how to do is I guess the question. Do you screw it down on 1 side then heat it to make the curve ?I have 4.30 gears in my Dana with 29.5 x 10.5 slicks & 4800 stall converter, leaving off of the transbrake. I made my windows out of a sheet of Lexan I acquired from a friend, it wasn't fun but I have a "lot" less money in mine than they want for them precut.
Thank you for the tipI cut it to fit & start in the middle working out 2-3 on each side using pop rivets
How did you get gold member status?I cut it to fit & start in the middle working out 2-3 on each side using pop rivets
I guess 1 of the other thing would be to remove the undercutting as much as possibeDitch as much cast iron pieces off that 472 as you can. Use a B/RB aluminum water pump housing, aluminum heads, aluminum intake, aluminum water pump, aluminum radiator, ditch the power steering for an aluminum manual chuck, remove your heater box, all the carpeting, spare tire, jack, trunk mat, and the afore mentioned back seat. Fix rear quarter windows in place, remove rear window regulators. This will lighten it up a lot more. I wouldent pull out window regulators in the front doors which would probably be a small nicety to have. This is gonna save you a lot more weight than carving on the thin unibody sheetmetal with a plasma cutter and possibly weakening the crap out of it. The only fiberglass parts that will save you a bit of weight over steel will be "race glass" parts like fenders. However, these will not hold up for over the road use in the long haul and will tend to start cracking as they are very thin for light weight on a drag race only car. A 4 pin light weight lift off hood would be ok as well as fiberglass bumper and aluminum bumper brackets.
Yes, I plan on it being a street car (for now)Look for all the "low hanging fruit" so to speak. All the stuff you can remove or swap out with lighter components. Is it gonna be a street car? You will still need horns to keep it legal. Get a single Hi Note plastic horn off a late model chrysler vehicle, ditch the cast aluminum and steel dual horns.
Move battery to the trunk. It's not removal of weight but is relocation of it.
Get a torch and heat and remove ALL that black asphalt based undercoating /sound deadened in the wheel wells, inside the doors, rear quarters, and under the car. That **** probably adds a good 25-30 lbs to it.
Get some thick aluminum plate. Trace your alternator brackets onto that and cut it out. Ditch the steel for aluminum. Add a circular lightening hole in the middle of the triangular bracket.
Hope this gives you some more helpful ideas.
Thumperdart that sounds familiar.Dominic which he goes by Thumper Dart has a Badass 70/71 dart swinger that is his street car. He races it once in awhile. If I remember right he has a pump gas low deck stroker 470. It's been a long time but I think he ran a 9.64 in the 1/4. But it is a true 9 second street car.
I used to have a 73 dart swinger with a .030 over 440. It had wisco flat top pistons, very mild bowl ported indy EZ heads. A Comp Roller version of the mopar 312/590 cam. Weiand Tunnel Ram. 2 750 holley DP carbs, 727 with a 9.5 Dynamic 4400 stall, 8-3/4 with 4.30 gears and M/T 275/60/15 ET street Radials. The car weighed 3520 with me in it and racing on 93 pump gas. I ran 10.59 at 125 in the 1/4. I let my friend race it that weighed a 100 pounds less than me. He ran a few 10.49 at 126 in the 1/4 on the same day. I drove it on the street once in awhile. I think my car would of been faster with the 4.10 but I blew them up on its 5th pass. So I had a set of 4.30 laying around. So I put them in. I also think it would of been faster with a higher stall converter. I did install a 8 inch 5500 stall converter but never got to try it out before I sold it.
Sounds like a nice car. Have any pics of it? My 440 was right at 10.9 compression.Thumperdart that sounds familiar.
Mine is sitting at 11.2:1 static compression
And my dynamic is 8.68, Hopefully I'll be able to run pump gas. I do have as much aluminum as possible & it should be cool under the hood with the coated fenderwell headers
No pics yet, it's just a rust free f4 green dart. Anything ive referenced so far is just what it's going to be based on parts I have.Sounds like a nice car. Have any pics of it? My 440 was right at 10.9 compression.
Is there something different about a 67 a-body k-member ? I think I read there's somethingYou can do a lot of trimming to the k member to lighten it up some and make more clearance room. Just make sure to reweld the seems.
Thanks, I thought I heard that. Is there any way to tell ? I got a k-member that is ready for the Schumacher mounts & was going to clean it up but 1st want to make sure I'm not wasting my timeThere’s several bastard parts on 67 A bodies. The idler arm is different and maybe the pitman.
Yes that makes sense thank you ill check in the morningThe 68 and later idler mount is two brackets welded to the k member. The idler slips between them with a bolt through the whole deal. IIRC the 67 has a single bracket and there is a ball joint type stud in the arm, if that makes sense. It seems the 67 piece is more expensive than the later ones.
Cool thanks budReal world weight loss program and it` cost.......... - Moparts Forums
Check it out over on moparts
