Aluminum spring eye steel inserts
Okibonoe
San diego
Hey there guys, I have a set of aluminum spring eye bushing that are 2.05 in od and are the nominal 2.50 in width. However I don't have the steel sleeve inserts for the bolt eyes. Any leads?
Thanks!
Thanks!
Are you looking for parts? We use wanted threads for that here. Give it a try.
Frankly, I'm not sure what piece is used, so I didn't quite know what I would be asking for. Didn't know if folks made their own or something.
If you know who made the bushings, they should be able to supply the sleeves.
If not, get accurate measurements of the ID and OD and call Calvert or Competiton engineering and see if they have something.
Or you can source some tubing locally and cut it to length.
