When I built my shop 6-7 years ago in installed 12 2 bulb 4’ T-8 Florissant fixtures. I noticed yesterday that I have one set that is out. My question is what bulb can I start replacing them with that are the brightest available? Thanks
All my LEDs fire up immediately. No delay at all. Seldom gets below 20 here but I'm betting they fire up at any temp.Do the LED 4 footers fire right up in the wintertime when the garage temp goes below 20 degrees? My old ones flicker and sometimes don't come on when the temp drops below 40.
We use mostly 4 ft t8s at work. Without changing ballasts, I recommend 5000k bulbs. That's what we use in 'work' areas. Warehouse areas I run the slightly warmer 4100k. And office areas get 3500k. Bulbs lose a lot of lumens over their lifespan So even using the same as you had - new bulb is going to give more light.When I built my shop 6-7 years ago in installed 12 2 bulb 4’ T-8 Florissant fixtures. I noticed yesterday that I have one set that is out. My question is what bulb can I start replacing them with that are the brightest available? Thanks
Are you saying LED's or Flourescents flicker? I had experimented with some LED's in -20 freezer warehouse and most were instant on full brightness. We ran mostly 4ft T5s there. Not sure how much is due to bulb size, but in my experience T12s have trouble in lower temps. But that may also be cause they are more likely to have ancient magnetic ballasts in them. T8 with an electronic ballast should be good down to 20F or even lower. They may not come on at full brightness, but should have no problem firing.Do the LED 4 footers fire right up in the wintertime when the garage temp goes below 20 degrees? My old ones flicker and sometimes don't come on when the temp drops below 40.
Yeh I saw where you are. My sister in law and family are in Spring Hill. When we went to Disney years ago Christmas week, it was getting too chilly for Tshirts later in the day and we got Mickey sweatshirts, LOLMy T-8’s have always turned right on. But then I live in Fl.
sounds like either way someone is going up a ladder, to at least change out the burned out one. just swap em' out as need beThis is what I’m dealing with. I’m not able to climb a latter 12 times and work overhead that much. Hell I’ll get dizzy and fall. Probably break a perfectly good neck.
Well I figure after 6-7 years they’re going to start burning out. So I’m going to replace them.sounds like either way someone is going up a ladder, to at least change out the burned out one. just swap em' out as need be
