What’s everyone using for a master cylinder when they convert to 4 wheel discs. Do I have to change the splitter valve or whatever it’s called down on the frame. Do I need an adjustable prop valve. This is on a 73 Cuda with power brakes. Altercation with Wilwoods on the front. They put a new factory booster and master cylinder on it a month ago when it was restored. Now I get to work the bugs out of the whole car. Thanks. Kim
