What Size 14" Tires? 70 Duster
It’s not a ‘70 Duster but it’s the same size tire as post #23 is running (235/60/14).
Well looks like I need to find some SBP slot mags for the rear
With the old setup, the rim was about 2" from the leaf springs..........so I assume the backspacing was the issue
If anyone knows of some or had some, please let me know
I would like a 14x7 or 14x8
almost certain i got a set of 14X7s in the garage...they may be 14X8
im out in michigan
need me to check?
Yes please! Pics and backspacing?
They need a good cleaning, but i wiped one down to get the numbers off it
They a 14x7s with 3 1/2 inches of backspacing
These were on the front so the tires are 195/70s with not much thread left, but if you want them, they are yours
How will 14x7s with 3-3/8" backspacing do on the rear end of my Duster?
I couldnt find any good 205s locally...........I bought two used from a tire shop on Ebay
Used, really good tread and was only $109 shipped for two!
You could have bought them new for $70 a tire, from Tire Rack shipped, just put 4 new ones on my Duster.
