Markzilla88
Hey all, this is a new problem for my car. My brake lights and dome light fuse keep blowing. It’s not an instantaneous thing, but I’ll get a couple miles and they’ll blow. Does anyone know of a common issue that may be causing this??
Only recent change I’ve made was I put an LED flasher unit in to eliminate hyper flash. I’ve had LED brake lights in the entire time I’ve owned the car with no issues other then hyperflash. It worked but now I’m wondering if it’s causing the fuse to blow.
