I would have to see a picture of the top down or back, off, ?
Or is just the vinyl trim with ribs under it that makes it look like a convertible.
First for me.
hmm it's got the outer stainless trim from a convertible so it might be a targa style top with the front latches of the convertible and pins into the rear section. but I'd worry about the flex in the body with the top off.
Subframe connectors will fix that right up.hmm it's got the outer stainless trim from a convertible so it might be a targa style top with the front latches of the convertible and pins into the rear section. but I'd worry about the flex in the body with the top off.
ditch the rear glass while the top is down! Of course, where you gonna put it?
Had it been done as a notch back (post 14, 3rd picture) the glass could have been motorized to drop down. Sort of like how the corvette has the drop down rear window.Imagine how much horsepower you would need to move that with the top off. That rear glass is going to act like a parachute.
