[SOLD] Keystone 14x6 SBP
matthon
Direct bolt, sbp, 14x6, 3 5/8 backspace.
Pics tell the tale.
I was unable to locate any cracks or other major damage.
These are rough, no doubt.
No center caps on either wheel.
Center cap in pic is gone, was too large anyway.
Comes with two TORNADO F70-14 old school tires, sweet if you like dry rot.
$100, must pick up at or near 12302.
Trying to find a local place willing to remove tires without purchase of new tires - really, come on, no, really. If I get lucky I'll update.
Deflate and put a bumper jack base on the sidewall and jack up your car, it will break the bead. Then you can just use a crowbar to work it off the rim. Nuclear option is break the bead and cut off tire through the beads. I rocked tires worse looking that than in high school!
Any of those big coprporate tire shops like Mavis prob wont help.
Best bet is to try a small Mop and Pop tire shop, or even a mechanic shop that may have an older Coats tire machine there. Offer them a few bucks.
Keep in mind, most places will prob charge to get rid of your old tires.
Can ship now, but I'll need time to make a box if they sell.
The tires aren't really that horrible, the tread is excellent, but I still wouldn't use them.
Maybe I can repurpose them.
Both still had air in them, and by the looks of the inside rim they've been on a long time.
$100 plus shipping.
