TexasDart
I also have 2 recumbent bikes. Start and end with cardio. I actually like those health rider bikes. They give you a pretty good overall work out.
Say it ain't so!
Awesome job! I been sober 5 years this December! I was a heavy drinker I'm glad I quit when I did!One of my boys turns 7 Saturday. It will be 250 days off the sauce. (Don’t plan on ever drinking again)
my goal isnt too much on weight loss, more shaping flab into muscle
according to the wife i "carry my weight well"
not sure what that means, but, just got a little flab on the belly id like to tone up
other than that, just health reasons
The bare small blocks must be getting heavier each production year!!!
Or maybe I should switch to aluminum blocks!!!!! Never thought of that!!you just need to use the ones that are punches out 60 thou.
Totally agree with the Athlean x comment.
Some may disagree, weight is not really lost in the gym. It is lost in the kitchen. Without a change in diet, your actual weight loss will be way less if you only lift. Won’t even be close.
That's pretty impressive for pushing 70! Keep it up! I carried my bare block up the stairs and mounted it to the engine stand without a lift. I'm young tho I don't think I will be able to do that stuff when I'm 50 plus lolI don't need to lose any weight at all, I have the perfect physique....LOL!! I'll be 69 in a couple of months and work out for 20 min on my elliptical 6 to 7 days a week. I get my heart rate up to 125 the majority of the time while I exercise. 128 beats per minute is the recommended maximum for my age. I do 15-20 push-ups every other day and few squats. No weights...too many injuries over the years. I can still lift and carry a bare small block.....but can't carry it nearly as far as I used to. The bare small blocks must be getting heavier each production year!!!
Say it ain't so!
been about two weeks and i think ive been using it a good 5 days a week
heres the routine im using
800 reps on the bike as a warm up
then 3 sets of 10-15 reps of the following
low pulley shrugs, #4 (60 lbs)
preacher curls, #4 (60 lbs)
leg extensions, #6 (80 lbs)
flat chest press, #6 (96 lbs)
butterflies, #6 (40 lb per arm)
behind the neck pull down, #6 (80 lbs)
frontal pull down, #7 (90 lbs)
high pulley ab crunch #6 (80 lbs)
then i add this 7 minute abb work out
and finally 400 more reps on the bike to cool down
the whole drill take me about an hour and 15 minutes
havent noticed any weight changes, or flattening of the stomach, but i have noticed some muscle growth on my arms
Awesome! I don't know how old you are but, higher reps/lower weight is smarter. Your tendon/bone connection will strengthen. Gets worse with age.
I have an impingement in my right shoulder that I have been trying to work through for 2 yrs, and I'm finally able to do full body dips for reps again. Patience is a virtue.
You may have to move to a 1 week split to prevent nervous system fatigue. Your grip will start to weaken.
Keep it up! Let us know of any changes.
At 37, im still younger then the cars I drive, so I should be able to still bulk up some, but ill watch for that fatigue and adjust if needed
I dont know, you may be disappointedYeah! you'll be fine (can I trade ages with ya? for a week?)
Yes sir! That's how it's done! Good job my friend!I lost 60 pounds quit drinking soda and sweets. And started doing push ups squats and resistance band exercises.
