318 EFI and carb
What year did Dodge stop using carburetors on 318s and switch to EFI? Can the later EFI engine be converted to carburetor by swapping the intake from the earlier 318? I need an easy fix for a smoking 1974 Duster.
DickJ
Why not look into a FiTech or Holley sniper to replace the carb?
Well, you can buy a used Holley for $50. $35 later you have a rebuild kit, and they work quite well.
The FI stuff is nice, but for a possible 10% increase in mileage, $1,000 is a lot to spend.
If I did have the money just laying around, I would probably go FI on a daily driver.
agreed, that's a lot of miles that the 'slightly' more economical setup has to do to even break even let alone start saving money. yes i know the driveability is improved somewhat but i've got my daily if i want to drive nice. my toy doesn't need daily driver manners. :thumbsup:
neil.
