Good morning
good luck, these new trucks are a pain I bet to find the drain2011 super duty with intermittent parasitic drain. Been chasing it for months. It never happens when its here. Well, it does, but i never catch it. put my tester on it and it wont drain battery. Im usually pretty good at finding these issues, but this one is smart.
No downside I know of. A buddy did that to his 318 heads and his teen screams!Got a question about J heads. Can anyone tell me what the down side is to upsizing intake valve from 1.88 to 2.02 is (as compared to getting factory 2.02). I was reading on a thread about "bowl size" being too small if you do that, didn't really understand if that was critical. Comments?
What are you putting them on?Thanks all for the comments on intake valve upsize, think I'll grab up those J heads.
69 340
Good Morning folks
The jugs stick out above the block .018 so there aren't any interference issues with a modified J head then, since same casting?
Same ole thing, headed to work. You?Good Morning Mark! What's going on today?
