Road Grabber
I am getting ready to send a body out for work but need to know what is wrong with my bottom radiator support which I believe has been bent while someone towed it.
Can anyone provide a closeup picture of the bottom radiator support and how it is bolted to a steel stamped connector between the K-frame and the support?
When I try to connect the piece I have it's way off. Too low. I need a photo of this area so I can try to fix it or tell someone how it needs to be bent back to the correct shape.
It means looking from under the car to get a photo of a car assembled or even better if you happen to have a shot without the motor installed showing the steel support from the k-frame bolted to the bottom radiator sheet metal support.
I will work on providing a picture of mine the way it is now shortly if that helps.
As always
Thank you
As always
Thank you
