Evan Dutch
Hi all,
A little while ago I purchased a 17 gallon oil drain tank to use for fluid changes under my two post lift. It is almost time to empty it so that I can take the used fluids (oil, coolant, gas, etc.) to my local automotive fluid disposer.
What does everyone use as a container for their used fluids? I've found the small 3 gallon oil recycle jugs online but I'd prefer to have them a little larger so that I wont have so many of them sitting around.
Thanks
Thanks
