We just bought a new set unfortunately. Frigidaire NG dryer and washing machine.
Before you buy do your research on who provides the warranty. Home Depot had the same model and they provide zero warranty. The extended warranty was provided by same hack company with horrific reviews.
We bought from Ma n Pa for about $200 more, but they are the authorized repair center for both initial and extended warranty.
So is it leaking oil or water?
Oh, also chk motor HP specs when comparing machines. Owner of shop we bought from said most all the motors are same size. So if the tub is larger and HP is same then the motor works harder.
Why am I advising on a "skirtwork" thread??
Oh check availability...might be scarce.
