452 heads Ported by Robert Landy of DLI.
Hello what I have here is a rebuilt set of ported “452” heads with oversized Stainless Steel valves. These heads were given a porting job similar to the Mopar Performance porting temples specs and was done by Robert Landy (Dick Landy son).
First these heads were decked .040 and that gave a combustion chamber down around 76cc. The intake face was also shaved so there will be no problems with intake fitment. New bronze valve guides were installed and The valve guide boss was cut down to except PC valve seals. This modification would also allow double springs. Mopar Performance 2.14 and 1.81 Stainless Steet valves were installed. Then came the porting job. Nothing over the top just cleaned up and open up to let the oversized valves work. These heads were never put on a flow bench but my 20 years of cylinder head experience tells me that these heads will feed a 465 to 485+hp engine with no problems. Valves were then “lapped in” and you can see the nice pattern left in the dykem. The heads were then assembled using Driven assembly grease. New Comp Cams #911-16 valve spring, 10 degree locks and Comp Cam valve spring cups were then installed. Valve springs have a seat pressure around 135lbs and a open pressure of 309@1.400 lift. These springs will work with a cam up to a .525ish lift.
These heads will work perfectly on a wormed over 383 or 440 up to 485hp and will also feed a 500ci. stroker motor. Anything over that just but a new set of aluminum heads LOL!! If your building a restored car with a wormed over engine, these would be perfect for you, stock looks with good performance. What else could you ask for!!
Thanks for reading, Troy
Im in Simi Valley CA, sorry but I can only ship to the lower 48 states. I prefer PayPal. Thanks
$675.00 OBO plus shipping
again.
$675.00 push shipping.
again.
