[Found!] Clutch pedal
mikec
hampton
Looking for clutch pedal that had 6” between the pins. Mine is the 5-1/4” pedal need some more throw on pedal for diaphragm clutch. Thanks. Located in nj 08827.
looking for a pedal that has 6" between pins , mine is a 6 cylinder clutch pedal on a v8 small block setup . i know can be modified but my fab work is not great lol
I have a pedal from a 340 swinger 3 speed car and it is also 5.25”. Did they actually make an A body pedal that is 6.0”?
If you know the application a 6.0” pedal came in it could help your search.
Do you know a guy with a welder? If you feel like your fab skills arent sharp, its always good to know a guy. Sometimes it takes a couple trips to find the right guy. Could be your neighbor.....old dude down the street.....never know....time well spent to find a guy that can weld **** together. OR......get a 110 gas sheilder and get dangerous! oh...and a 4" grinder. Whats the saying? I dont have to be a good welder as long as Im a good grinder? (Is that what she.....) I say get dangerous bro...break it.....fix it again...
good luck!!!
IMO... go 5-5/8"...I have extended several to 5-7/8, but only for strip cars, no street duty. Tried the 5-7/8 on the street and returned it to 5-5/8 ASAP.
Thanks for all information everyone . I’ll look for local guy to modify
