[WANTED] 273 Timing Chain Cover pn 2128896
FJRdoc
Brownstown, PA
Hi gang.
I need a timing chain cover for a 1967 273 engine. Part number 2128896. This is the cover that does not have timing markings on the driver's side.
I'm just looking for that particular casting number. The original cover was eroded around the water jacket and concerns me that it won't seal properly.
I have one. It's the last casting (1976), but it has that casting number. The only real difference between it and the earlier versions is it doesn't have that extra hole on the driver's side. Similar to the '70-up version.
Thanks for checking Mark. Another FABO member connected with me and he has a cover with the same casting number that I need. I'll keep you in mind if things fall through.
