Fan clutch choice
Gee. I think that made me feel bad. :( Used to be a 290º@.008" duration cam was close to as hot as it got on the street.
I'll have you know I have over 7" of vacuum at idle!!! ;) ..not eight, but over seven.
Seven inches of vaccum is not to bad.
My stroker BBM had 2-3 inches at idle, what a ***** to tune.
Was not trying to make you feel bad....
That comment was not directed in your direction...was all tongue-in-cheek anyway.
No one is going to 'make me' feel bad about anything, particularly having owned my A-body for 47 years, nor the path it's been on to get to what it is now.
Getting rid of my '68 Charger R/T 440HP because 'everybody knows...' (at the time) that it took a '69 396 Chevelle to make a REAL hot rod? I feel plenty bad about that all by myself. ...not to mention a couple of other 440 Chargers I've gotten rid of. ...not to mention my '67 Dart 273 GT.
Me as well. '69 Dart Swinger 340
'71 Demon 340
And a damper and timing cover change. And the pulleys.
For sure. I went the other way on my 1965 273, installing the later aluminum water pump. The reason was because I could only get the later radiator at Autozone. That was early in my resto before I knew of options. I didn't have to change the damper, but couldn't use the TRW power steering pump because the aluminum water pump doesn't fit its brackets, so had to change to a later Federal pump. I also had to rearrange the belts, sharing the water and p.s. pumps on the same belt (recall). I thought I could use the TRW p.s. pump on my 1965 Newport, but found it's TRW pump needs a different pulley and the pumps have different diameter shafts. "Nothing fits, or is easy" is the best summary.
Unless you are trying to gain 1/2 mpg just go OEM fixed 7 blade.
Would you recommend the standard or the heavy duty clutch for that? Tampa Bay heat.. then I'm also looking for performance gains, then some people have told me it seems like the heavy duty clutch Never disengages fast enough...
The HD unit will not slip a much as the standard.
So the HD will provide more air.
I have had several clutch fans when your driving you cant tell when the fan engages or disengages. That sounds like interweb bullshit.
Keep in mind the clutch never locks up 1:1 even when they are fully engaged they still slip a lot.
