72Dart6pack
Harder Better Faster Stronger.
New 6 leaf springs from John R spring. Same place Mancini gets them from.
I like all the pictures and the ride height shown but these springs move the rear forward . OK with little tires but not with larger Diameter.
I have a set here I removed. there was 3/8 of an inch difference on location. They also stretch the rear shackles forward due to arch.
Offset shackles should be used with these springs . they look like a Z from the side. Or shim the rear hangers forward. B-bodys don't have the removable hangers you must use the offsets. Also shim the front spring hangers back. 3/8 flat stock with the holes drilled for placement on the studs before installing the front hangers.
Measure this distance below from side to side. The difference is usually the size of the shim needed to straighten the rear in the car. Most are usually off around 3/8. 340 4 spd cars with boxes and sure grips are usually located correctly but not all. The reason why most /6 and 318 cars ride sway back. The picture below is a 340 auto. It was off 3/8 that area shown is usually much wider when correct.
The incorrect position can be seen easy when we put it on a body fixture as seen below. Incorrect position is what will tear up a sure grip and cause a handling problem . Just some info and a thought you all should consider.
Running mopar s/s springs on my dart and 68 coronet, they are nowhere near that high !
Thanks! 002/003 on the dart and 2 457's on the coronetThat looks perfect! Those the 2800 lb SS springs?
