[FOR SALE] A833 4-Speed
JWRICH
Edit/UPDATE: Reducing price now after investigating cost of the parts id need to purchase to rebuild this. Now asking $375
A-Body Mopar A833 4-speed. 23 spline input, 26 spline output. Will need a few parts to complete the rebuild. All gears look excellent. Will need the 1-2 shift fork and shift lever, ball/detent parts, and side cover bolts. It was previously set up with a 1-2 synchronizer with the wide keys and a 3-4 synchronizer with narrow keys. Can be rebuilt to a nice unit with a few parts.
Local pickup only in Marshalltown, IA. 50158
Do you know what year transmissions this is?
Looking for the first gear ratio.
counter gear looks like a 2.66 ratio, which is common for the 66 / 67 trans.
Main case: 96561
Tail housing: 96706
Gear tooth counts are as follows: 35, 34, 29, 24
Ratios therefore should be: 2.66, 1.91, 1.39, 1.00
Price lowered to $375. Should be a fair deal for someone!
