Haney
www.carsonandironmt.com
1972 Dodge Dart Swinger. This is a very original car with brake and suspension upgrades. I started with a “survivor” that was wearing 70% original paint, original interior, and vinyl top. It has 75,*** miles. It has the factory 318, 2bbl, 904 Colum Auto that is all original. It is a manual brake, power steering car with factory AC. AC works, but has a leak. When blowing it is ice cold.
This car has NEVER had any rust or body damage. It is as solid of a 1972 Dart that you will find. Dry and wearing factory undercoat. I painted the car and added the tail stripe.
Brakes have been converted to 5x4.5 with Mopar slider disk from Doc Diff up front with drilled and slotted rotors. The back brakes have been converted to Right Stuff Disks with parking brake. The master cylinder is a late model Mopar aluminum unit.
Rear end is a 70 B-Body with a 489 3.55 Sure Grip. Perches moved in to 42” and Dr. Diff A-Body inboard kit installed. Springs are XHD Springs and Things 5 leaf.
Front suspension has a set of Firm Feel 1” T-Bars, Firm Feel Tubular Upper Arms, Boxed lower control arms, new pitman arm, new idler, adjustable strut rods, new ball joints, new PST large tie rod ends. It has Bilstein Shocks on all four corners. The wheels are 17” Mustang Bullet wheels and 245/45/17s front and back. This car drive and rides better than new. Handles great.
Car has brand new 2.5 exhaust from factory manifolds and sounds great.
Interior is original and in great condition. Carpet showing wear but it too is original.
This is a great car I was building to keep but another car I use to own is becoming available and I want to buy it back. This one has to go to make room. I am not interested in trades. This is a great car. No rattles and is tight as brand new. Get in and drive. Factory AM works great as do all lights, accessories, etc. Glass is mint. I will supply any other photos, videos, etc as needed but please only if you are truly interested.
Price is $18,900 OBO. Located in Piney Flats, TN. Message me if interested.
