2021 "CAR" resolutions....
Do the Tremec 5 speed conversion in THIS:
Take the transmission from the red car and put it in THIS:
Sell THIS:
Finish THIS:
Drive THIS more too !
I'm not callin it a resolution but I AM going to work on my projects more.
I will get the fastback running and driving. My girl wanted a 69 mach 1....I know, I know.....but I got her one. its in a couple of peices.....so theres that to put together and get to paint.
Adding the 15" X 7" Rallyes (with 245-60R15 tires) on the rear:
And... making an insurance claim for the damage caused by some patio chairs deciding to vacate their winter spot
68 Cuda:
  1. Buy/Install 13” front disk brakes with aluminum hub and rotor hat
  2. Determine rim backspace for max front tire width
  3. Buy/Install 18x10(11”) ET or Vintage Wheel Works rims
  4. Match rear end width to front rim backspacing
  5. Determine if rear wheel wells need modifying
  6. Modify rear wheel wells if needed
  7. Install spring saddles for correct pinion angle
  8. Make brackets and hoses for aluminum power steering pump and remote resivour
  9. Buy/Install Firm Feel Idler ball bearing kit
  10. Determine reliability of Borgenson PS gear and purchase or install Firm Feel PS gear and flaming river joint
  11. Buy/Install Firm Feel steering sector support kit
  12. Pick a manual transmission with good road race gear spacing...factory, Nash 5 spd, or buy Tremec, etc
  13. Remove engine, trans, k-member
  14. Reseal engine
  15. Install and fabricate for trans install
  16. Replace UCA & tie rod Heims
Whew :realcrazy::eek:
Gotta get the new 360 in the Duster for when the snow melts.
Gotta get the truck dinished and on the road by the end of May! That will be the tough one!
Cley
What is that on the floor with the handle hole in it? Is that like a big knee pad? I could use one of those!
@RustyRatRod
If y'all have a big fabric store close by, that cuts and sells foam....go look around in there. I went in one here with my wife, and wandered off so I could quit making up opinions about this or that pattern.....and found some foam pads a lot like those in the pic. They're about 2' wide, and at least 3' long. Plenty big enough for my lard butt to lay on in the floor to work. They were about $5 each if I remember right. They are slick, closed cell foam, and easy to wipe off.
1. Spare engines built and sold.
2. Imperial bodywork and paint fine and car sold.
3. Engine for my ‘65 assembled.
4. Headers for my ‘65 built.
5. Start resto on my Chevelle (flip).
ive already got three customer engines to do in and around those so we’ll see. GF wants the house renovations done too. How many days in 2021 again?
I was just going to change the intake and carb, but then I did a compression test and found a low cylinder, so the heads are coming off. Well if I have it torn down that far I might as well change the cam.......
Tune the bog out of of my speed demon no matter how many years it takes!
So it begins...
Graduate Dental School... Make Money...
Fix A/c system.
Adjust rear window
New Springs
New Torsion Bars
Better flowing heads
LED dash lights
All the other little projects I find
