Sorry to ask yet another drive shaft question, but I have searched to no avail. I need the drive shaft length (u-joint center to center) for an early A body manual transmission with slip yoke and 7 1/4 rear end. Thank you.
I have 5 different Mopar Drive shafts and cant find any matches on the dumb mopar charts.
Dart would be longer than a valiant 63-66 really only 66 used a slip yoke drive shaft and 67 and later are also different because of wheel base.
Well thank you! That narrows it down then. I need the drive shaft length for a 66 Valiant 2 door seeeeedan with a three speed (or 904) and 7 1/4.
I have one I will measure it for you tomorrow.
I have one I wille slip yoke measure it for you tomorrow.
