Stop in for a cup of coffee
1018 cases and 22 deaths here, a lot from one retirement home in Coupeville. Sure could be worse and probably will be. Good news is they put out a vaccine schedule, wife will qualify before me unless retired military or utility worker goes up in priority.
Hell of a search today. Just stuff
1967 Chrysler rear speaker control package NOS 2820769 - auto parts... (craigslist.org)
MoPar Dodge Plymouth Chrysler 10 Slot Rallye Wheels - auto parts -... (craigslist.org)
Chrysler Sebring convertible top Daylight assembly - auto parts - by... (craigslist.org)
Mopar Gear drive timing set - auto parts - by owner - vehicle... (craigslist.org)
1966 1970 NOS Mopar B Body Hurst 4 Speed Shifter Charger 440 - auto... (craigslist.org)
MOPAR ! 1975-'76 PLYMOUTH "Duster and Scamp" Headlight TRIM RINGS -... (craigslist.org)
340-383-440 MoPar Engine Parts - auto parts - by owner - vehicle... (craigslist.org)
NOS. Gas Cap 1970 - 1974 Cuda & Challenger - auto parts - by owner -... (craigslist.org)
MOPAR PART'S-1963 PLYMOUTH FURY - auto parts - by owner - vehicle... (craigslist.org)
70's mopar grille retainers - auto parts - by owner - vehicle... (craigslist.org)
NOS Mopar GM Ford Goodyear Polyglas Tires Chevy Pontiac AMC - auto... (craigslist.org)
70 Plymouth Road Runner Parts - auto parts - by owner - vehicle... (craigslist.org)
426 Hemi engine apart 1967-68 Mopar - auto parts - by owner -... (craigslist.org) Seriously that much?
Mopar Dodge NOS Courtesy Lamp PKG - auto parts - by owner - vehicle... (craigslist.org)
Mopar Rear Differential - auto parts - by owner - vehicle automotive... (craigslist.org)
1975 Dodge Dart Fenders RH And LH 1974 1976 Mopar Parts - auto parts... (craigslist.org)
COMP CAMS 3203 Timing Chain set for small block dodge/mopar - auto... (craigslist.org)
Mopar 1968 383 HP Carter AVS carburetor number 4426S - auto parts -... (craigslist.org)
Mopar A Body Sway bar / Front end - auto parts - by owner - vehicle... (craigslist.org)
1967-72 MOPAR A BODY SLANT 6 to SB 340 360 MOTOR MOUNT CONVERSION... (craigslist.org)
Original mopar parts dept. clock - auto parts - by owner - vehicle... (craigslist.org)
Mopar 9" brake drums - auto parts - by owner - vehicle automotive sale (craigslist.org)
MOPAR A-body Transmission Mount - auto parts - by owner - vehicle... (craigslist.org)
DynoMax Mufflers 3” Super Turbo 17793 Mopar Chevy Ford Plymouth... (craigslist.org)
Mopar Remote Mirror Road Runner Charger 66-70 A+B -body - auto parts... (craigslist.org)
Mopar Express Train - auto parts - by owner - vehicle automotive sale (craigslist.org)
Mopar Early A-Body Steering Column - auto parts - by owner - vehicle... (craigslist.org)
8 3/4 Mopar axle - auto parts - by owner - vehicle automotive sale (craigslist.org)
1968 Chrysler 300 Convertible 440 TNT 1966 1967 1969 1970 - auto... (craigslist.org)
mopar, dodge, plymonth big block valve covers - auto parts - by... (craigslist.org)
1970 Mopar 340 block - auto parts - by owner - vehicle automotive sale (craigslist.org)
Mopar Performance Indicator - auto parts - by owner - vehicle... (craigslist.org)
MOPAR HIGH TORQUE MINI STARTER FITS 1966-99, 6 CYLINDER AND ALL V-8... (craigslist.org)
Mopar,Tic Toc plymouth dodge 1970 dash clock - auto parts - by owner... (craigslist.org)
1961 Plymouth Camino Hotrod/Rat Rod Project - auto parts - by owner... (craigslist.org) I am speechless
1968 mopar service manual - auto parts - by owner - vehicle... (craigslist.org)
Mopar 4-speed parts - auto parts - by owner - vehicle automotive sale (craigslist.org)
Vintage Mopar Remote Driver Side Mirror - auto parts - by owner -... (craigslist.org)
Mopar Radio stereo cb combo - auto parts - by owner - vehicle... (craigslist.org)
mopar od trans - auto parts - by owner - vehicle automotive sale (craigslist.org)
Mopar 8.3/4 ring &pinion323 - auto parts - by owner - vehicle... (craigslist.org)
1970-1977 Mopar turn signal switch - auto parts - by owner - vehicle... (craigslist.org)
Mopar rear end gearing - auto parts - by owner - vehicle automotive... (craigslist.org)
Mopar Tachometer - auto parts - by owner - vehicle automotive sale (craigslist.org)
91711 Howards Cams lifters - auto parts - by owner - vehicle... (craigslist.org)
Chrysler Mopar 8 3/4 rear differential carrier 3:23 ratio 2881489 -... (craigslist.org)
Mopar Valve Tappets 2469501 - auto parts - by owner - vehicle... (craigslist.org)
Mopar 8 inch Power Brake Booster "Brand NEW" - auto parts - by owner... (craigslist.org)
MOPAR early 60s ALUMINUM BLOCK 225 SLANT SIX ENGINE DODGE PLYMOUTH -... (craigslist.org)
MOPAR AM-FM Radio 1963 1964 Dodge Plymouth Chrysler - auto parts -... (craigslist.org)
No Chris no
Most of ours are nursing homes.
I wonder with all the nursing/retirement homes and 65+ deaths across the nation if nursing/retirement homes will shut down due to a lack of people in that age group??
550,000 cases here, mostly in Marion County and up around Chicago, 8900 deaths.
There's a Mopar parts clock in here, needs work, may only be right twice a day but I emailed on it, Thanks Hoppy!
I cherry pick the stuff I want then post the rest. Why I never read back, have to daily check for deals.
The big excitement out here yesterday was the tree trimmers, crews are subcontracted by the utility I work for and make rounds once a year or so. I flagged a dead standing alder and asked them if they could take it down as it's a leaner towards the power lines. They did a great job, clean up too!
Steve I have two more ecus for you that failed. I will wait till I test the 20 new ones I am getting.
Not a good idea to kill off your clients...
