C2ndLTpigeon
Mopar or no Car!
I have done some deep searching and have found a Fuel sender that is NOT a cheap knock off that will read incorrectly.
The OEM factory number that is stamped on the sender is 4051003 which after doing some reading was the part number that replaced the older numbers.
My question is will this be the right sender for my 1973 Plymouth valiant? The one that I currently have in there is the long throw variant. Everywhere you look shows the one pictured for sale but not the right signal so inaccurate readings.
