How many model years are in your car?
Wvbuzzmaster
West Virginia
So this could be fun. As we all experienced buying the older cars and parts off other cars for it, how many model years can you prove are in your car. Or what years do you have to look up just to get certain replacement parts?
My car: 1972 Plymouth Duster
1967 Dart power brake booster
1968 B Body 8-3/4
1969 casting 340
1970 hood and trunk lid
1971 production date
1972 model year
1973 disc brake swap
Volare front brake hoses
lessee
car itself: 71 duster
75 motor home: engine and transmission
68 dart: rear end
69 valiant: grille
chevy calipers
toyota discs
tahoe brake hoses
i think those are the most noteworthy parts (the last 3 of course came from a scare bird front brake conversion kit)
hmm,,,
65 valiant
67-76 floor
64 steering column
98 engine
87 front spindles and disc brakes
74 brake master cyl
Electronic dizzy, unknown year
GM HEI module
Diymirage, that is a great looking Duster, makes me want to grab a 69 Valiant grille for mine.
Thanks man
IMHO the Valiant grille is the best looking grille for that year duster, specially since it goes so well with the tail light
Best part is, it was pretty much a drop in
(Worst part is, it is a one year grill, so hard to find, and the marker lights were used only on the 69 valiant AND THE 69 Daytona, so the can be pricey)
70 Duster
Drivers door off 71 Duster
Drivers fender off different 70 Duster
Passenger fender of 71 Duster
71 340. Origin unknown.
4 speed from 68 Dart
8.75” rear of unknown origin.
67 Barracuda
68/69 Barracuda window trim
73+ electronic ignition
Alan
HMM
70 trailer hitch
74 body
70 boat 440
72 steering box
97 jeep 355 and rear disk brakes
82 van roof rack.verty caps
73 15" steel wheels
97 jeep spare
?? trim rings and poverty caps
I am sure I missed a bunch.
67 Barracuda
99 Ford Explorer 8.8
2004 5.7 and 545rfe
2005 BMW power seats
Aftermarket suspension
GM wiring harness
86 econoline (spare tire cover)for metal work in battery tray area in engine compartment
2000 Ford Taurus Fan
2005 Durango ECU
Date and application unknown:Serpentine belt (take old one to measure in back of store)
2011 Ford Fusion spare (hope my mother in law doesn’t get a flat)
Radiator Hoses same as above take in to store and go in the back and see what looks close.
It's a 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59 automobile....... Johnny Ca$h
1968 B Body 8-3/4
1969 casting 340
1972 model year
Maybe at some point ask how many different makes of cars or trucks your car is made up of.:D
65 Barracuda
'71 SG
'72 rallye rims, center caps
'86 360, 72 J heads(?)
'65 valvetrain
Or 1967 slant six, 1961 head
'68 904 transmission
'67 904 for the slant
'67 drives shaft
'88 Supra turbocharger
'88 EDIS-6 ignition
'96 Neon injectors
On and on....
70Dart
69 8/34 housings
68 743 3.91 sure grip
72 904
93 360 mag
92 650 double pumper
67 or so stock 14 wheels
Lists below do not include aftermarket wheels and engine parts (intake manifolds, carbs, cams, heads, etc.), or non-original colors
1967 Barracuda (original slant six car)
engine/trans from a junkyard 1974 Duster 360 (a rust-free example that should have been saved, but that was 30 years ago)
rear end from 69 Dart with swap meet 3.55 sure grip chunk
HD rear springs from my 65 Barracuda
4-piston disc brakes from I don't remember
69 steering column with original 67 chrome shifter
stainless steel windshield and rear window trim plus rear window gasket all came from a junkyard 68 Barracuda
ALL sheet metal is original
1965 Barracuda (original Commando 273/4-speed)
engine block, bellhousing, driveshaft, 3.23 sure-grip rear, and disc brakes from Mom's Duster 340 that my brother rolled in 1983
forged crank from 72 340 Charger (block was cracked in one cylinder - sleeved that cylinder and put it and the 71 crank in my stepson's 73 Duster 340)
K frame from 65 Dart (original was cracked)
trans from 69 Dart stuffed with original 65 3.09 low gear gearset
Body/interior parts are all 65 Barracuda, but not necessarily original to this car
1963 Valiant Signet 200 convertible
65 block (original was cracked)
later exhaust manifold I bought NOS from Don Garlits
67 Barracuda radiator with trimmed passenger side bracket, three row core and Jeep bottom tank
64 Valiant right front fender
64-6 sport steering wheel
outside remote control mirror (not available in 63 for Valiants)
They were actually made then of course a lawsuit by GG shut it down I heard. Look on flea bay once in a while they show up.
72 Dart
70-71 side markers
71 grill
73 hood scoop
73 K frame and front suspension.
Late 70's 11.75 rotors
2002 5.9 Magnum
67 833 tranny
Mid 70's cop car wheels
71 Charger bucket seats
75 inside hood release
71 Gull wing
72-4 E body Sport wheel
70 door panels
